x20xev turbo conversion
Raunds, Northants
im interested in getting a turbo kit off the www.mvaux.com website for a x20xe engine
does anyone kno if these are good kits and if mvaux are any good??
also what boost would be safe with this engine?
im only aiming for about 180bhp but would like more if i can (not being greedy lol)
are these kits DIY fitment (just like replacing a manifold and downpipe??
also would a remap or/and a 5th injector be needed??
his kits are good mate just have to make sure the manifold flanges are flat if tubular if cast it should be ok
Im not too clued up on mechanics but i did ask my mechanic about this sometime ago, he mentioned afew things - one i can rememeber is the compression ratio has to be changed to give more compression. Some1 else will be able to give a full list im sure.
you need less compression.......IE pistons changed.........I would think you need some sort of mamanagement change or a ffth injector (although I belive this is a pickey way of doing it) you will also need some sort of oil tap for the feed and return of the turbo...........
so I would think with just lower c/r and a the oil feeds that you should see an increase but lord knows how the standard management will cope....
says he is in brazil? with a couple of dealers elsewhere...
also £620 is a good price but seems a bit cheap? maybe the blower is a cheap foreign make?
