ok having a clear out as got another big change on the cards and could do with the cash for other bits postage is availble on most bits and can combine if you want a few bits
20seh engine and 20se engine with loom and ecu, 20seh the big ends went on but 20se is perfect so could be made into 20seh as bottom ends are the same £150 for the lot or offers as need it gone
spare 8 valve bits including
another 20seh inlet manifold with FPR and rail no idle control valve those £40 posted
20seh cutch and flywheel can split quite a bit of material left on the clutch can possible post will have to check weight £30
another 20seh inlet manifold with FPR and rail no idle control valve those £30 posted
20seh cutch and flywheel can split quite a bit of material left on the clutch can possible post will have to check weight £20
astra mk3 rear standard dampners £30 posted
astra mk3 lowering springs with rear spring hardners PI 60mm £30 posted
2 x F16 gearboxes one removed from the 20SE probably hardly used sat in my workshop for 4 years maybe. other has been sat outside for the last year but has had a rag in one of the driveshaft holes and still has oil in it but could do with a change im asuming these are bote CR boxes as were both attached to 2.0 litre 8 valve lumps
£40 for the one that has sat inside (non painted) missing clutch arm
£30 for the one outside blue paint
Collection only
im open to offers on everything and combined postage on stuff
thanks for looking
Collection only
thanks for looking
