Which 2 bolts?undo 2 bolts and it should shut tempory..
I would try blasting the catch with WD40/penetrating fluid, and using a screwdriver to free it up (as in simulating the loop on the B pillar)
Which 2 bolts?
there is 2 in the door, if wer on about the same thing,,
is it seized in the door or wer the pin goes through on the pillar?
Its down my drive next to a wallhas the pin been mis shaped? just whack it out.. you cant leave your door open all night?
i have a similar problem on my passenger rear door the little arm thing doesnt go back up i have to force it up to shut the door as if dont and just swing the door closed it just makes whacks against the eye bit very annoying as a copper pulled me over the other day for a "routine check" and searched my car only for me to be not paying attention to my car and he slammed the door shut ¬.¬ and he just stood there starring at me gormlessly with me at boiling point gritting my teeth saying just leave it please........ its fine just leave it open..........
