Alright guys
My mk4 is making a funny noise and wandering if you could supply your thoughts to two problems i cant seem to figure out.
Since de-restricting the airbox the car is now really loud with a big reverbarating sound inside the cabin, though doesnt seem to sound any differnt from outside the car, is this normal (as no differnce like this was made to my mk3 of vec b when de restricted them) or any thoughts on whats causing it?
So far check the mounting of the box, the air filter fitted correctly, tightend a screw which was loose where two of the box mountings fix. The sounds is nearly the same at like 2k-5k in the rev range with noise only slightly increasing from it, car revs up through and pulls through it fine. Is really startng to annoy me now and cant seem to get it sorted.
The other is i can get the 12v fag lighter to work. I have checked the fuses and cant see a blown fuse and cant imagine its the fuse as the light still comes on around the 12v hole. Also tried my 2nd lighter and got the still the same problem as thought i might have had a faulty one. and would like it so i can get the sat nav working again.
I know they run of a seperate power supply but as they share the same earth im guessing the fuse cant be the issue, also had to differnt fag lighters and both seem to be the same
Asked on both mig and aoc and neither have been overly helpful, where as you guys are normally pretty good, any ideas apprietiated.
Thanks
Will
Thanks
Will
resonator wasnt touched just the internal two pipes at each end.
