removing a door?
Ian
Pontypridd
am i right in thinking that to remove a door you just need one person to hold the door and the other one to tap the pin out with either a door pin remover or some sort of punch?
is it possible without a pin remover/punch? (havnt got one :rolleyes:)
^ Exactly what I was about to put. :beer:
Pull out the door check pin as well, this gives you a little more room to get to the hinges.
ok we tryed on the doors today and they wernt budgin any ideas also the steerin wheel we cant get it the 2 torx nuts from the back out
have you soaked the pins with wd40 also just bang the hindge its self might just give it some shock and losen it up a little think i used a flat end screwdriver when i did mine. its also worth tapping yhe pin back and forth while spraying wd40 on them hope this helps
The door pins can be very tight, i have them in the past were the door hindge has bent before the pins have moved, try and get some heat on them if they are severely tight, as for the torx screws on the steering wheel, i take it its the air bag wheel, once you have undone them then thats it, they don't come completely out the steering wheel unless you force them out,
