Urgent fuel tank wiring help needed
Fife
Trying to get the car ready for crail on sunday and what plugs go where and why doesnt the blue and red cabled plug fit in the fuel.pump is getting to me,
car started of as a 1.4 8v r reg, what i jeed to know is,
of the two plugs that go through to the fuel tank from behind the drivers seat, whick one goes to the sender unit (white??) and which one goes to the pump,
also, the black plug does not plug into the fuel pump, connections are different? I did take the tank out before xmas and daft me never labelles them, if someone coukd tell me if im missing someone thing and what goes where id be very very grateful!!
Red blue to fuel pump - white to sender.
Brown is earth.
Relay is controlled/earthed by the ECU, it closes the relay and powers the pump.
Btw, there is a separate plug at the front of the fuel tank. You can see it if you get under the car - it is just next to the grommet that goes through the body under the seat area.
