I always undo the shaft and push it back a bit. Then undo the ball joint but until it's inline with the top of the threaded bit, then get a chisel in between the cv joint and the nut and hammer it in until it pushes it out. Then use a pry bar to push the wishbone down enough to pull the leg forward.
Remove the nut.
Insert a large bar over the lower arm and locate it under the floor of the car so you apply downwards force on the wishbone.
Get an assistant to tap the casting of the strut where the balljoint fits while you heave the bar downwards.
The joint will pop out of its taper- zero damage and no need to use tools.
The steering track rod-to strut one is a b***ard though. Why are they always so tight?! I always use a decent scissor-type splitter on these, while tapping the strut where the balljoint sits again with a hammer.
If that doesn't work, I unbolt the track rod from the rack and take the whole thing to a vice and get medieval with it
I always use balljoint cracker on the arm and the wishbone I use 2 chisels one from each side and tap one in, it adds pressure from the driveshaft above and pops no problem. Just remember to put the nut on the last bit of thread to protect it from damage when you do this
