Ians 5dr Astra Turbo
thats a brilliant price mate! nice one!
STOP MAKIN BABIES!!!! might see you at PVS next year then!!!! instead of buying a pram!!! ha ha!! :-D
Defo be at PVS 2011..
You got some bargains on the engine and wheels there. Did the ibiza splitter on your old sport bumper fit ok or did you have to chop it about?
As far i can remember went on with no cutting hit every speed bump going though.. :lol::lol:
Good price that mate, is it all standard? it looks pretty clean
Yer eng is totally std but got some bits an pieces for it..
Little update..
The mileage on the turbo clocks ive got in the astra was miles out, the car is on 68k the clocks are on 118k :doh:, so did some thing about it..
Before..
Speedo head stripped out..
Changed to correct mileage for the astra..
And all built back up again..
Job done only took half an hour.. :heh:
Had a few hours on her today fitted omega bonnet struts..
o/s..
n/s..
also fitted new front breather hose as the other was fooked..
started running wires down a posts for my omega self tinting elec interia mirror, power down o/s and the other four down n/s got all headlining back up and sunvisors etc back on but thats as far as i got, no pics of this as phone battery was near on flat :doh:, will get some pics and continue with this when i next get chance..
very nice car mate :thumb:
Bit of an update, had a couple of hours on the astra so firstly fitted my turbo clocks back in..
Then got all the self tinting mirror wiring at the roof all solderd and insulated..
Just got to wire the +ve into the fuse box and three wires to the switch and one to the g/box switch wire then its done..
i hope your clocks read right mate, as astras start at 10 instead of zero, but i supose if you have the gearbox to match the clocks then it should be fine,
nice work bargin prices for the let and rims
balls to all the ABS stuff, more clutter in the bay than out else,
Where do all the wires go too?
Wires you need to use is:-
Black - switched +ve (might be two if so wire them together)
Brown - earth
Gray/Black - gray on interia light ( might be two so wire them together)
White/Black - to g/box switch in passenger footwell
Rest of the wires go to a electric mirror switch mounted in the centre console some where
Black/Red - to black/red on elec mirror switch
Blue/Red - to yellow on elec mirror switch
Blue/White - green on elec mirror switch
Then piggy back a black (switched +ve) and a brown (-ve ) from heated seat plugs and join:-
Black - black on elec mirror switch
Brown - brown on elec mirror switch
You should then have a fully functioning omega self tinting electricly operated mirror..
