my astra saloon sleeper
Wheels suit imo, colours nice, and the size is right.
What springs have you got on the front? I think you could go a tad lower for a nicer stance.
The last pics make a big difference, stop using your phone :nod:
ive got a S3 but needs a screen digitizer, so I got a cheap Galaxy Y, im going to use the digital camera from now on, its lowered 40mm on the front and 60 rear, once ive got my downpipe highten'd I might drop it a touch more.
As said on fb gareth i wasn't a fan at first but deffo am now :)
from todays show up in Penrith
if you want rare you want the 4stud snowflakes that come on a corsa, proper rare
who's talking rare wheels here :rolleyes:
you will know them when you see them im sure, and no they aint welded up, they are from factory but im sure they are only 15's :(
not a fan either, but rare lol
they cavalier irmscher optional extra from factory,
been quiet but been busy, as some know I had a bad oil leak, well it got worse running off the lower arms and into the wheel, all over basically so decided to set too and SORT it,,
the leak killed 2 Aux belts in 3-4months
so pulled the head off to find a split 'O'ring seal on the chain tensioner everything else was fine
so wile it was off I thought I mays well upgrade to B205 saabs are genius Double Valve springs as standard and better flow, larger inlet ports
cleaned the face up also checked it with a steel Rule for any warps
and finally got it all back together, new gasket set through out and new seals, refitted the b204 cams as they better for over 300bhp compared to the b205,
I haven't had it out yet as im gonna be dropping the sump off to clean it out incase theirs any dreaded sludge, then fresh oil and filter
