it was also running lumpy and the idle was a bit erratic and theres now a whistling sound aswell as chatter from the filter. Fault code is 114 ''boost pressure idle above upper limit'', actuators only on 2 turns of pre-load and it wasn't hitting boost cut before the eml came on so not sure wtf's going on now but it's starting to pee me off!!..
Had no idea LETs ran a vac pipe right up to the ECU, how odd! I really don't know LETs at all
Glad you fixed that issue though. And I like your thinking, if it doesn't work, upgrade it![]()
That vac pipe, ball ache much. Glad you sorted it ish though
so nursed it home the last few miles and parked it up. Was proper spewing over this but started to pull it to bit's to check it all out. Timing's all still spot on so the belt hasn't jumped but it didn't feel right when i was winding it round to the timing marks.
Pulled the plugs out and they seem fine so hopefully the pistons are still all good, i 'm borrowing a compression tester on monday but i'm fairly sure ive bent some valves.
