but after doing that it's probably revved to a good 10-15k rpm!
Hopefully bent valves is all it is, obviously no damage would be bestbut after doing that it's probably revved to a good 10-15k rpm!
What a knob. I've never understood how you can do this, I've always felt it if I've put it in the wrong gear and smacked the clutch back down. Hope it's not too bad mate, way too close to pvs for stuff like this
, tbh my gear linkage aint the tightest so was pretty easy to get the wrong gear..Hopefully bent valves is all it is, obviously no damage would be bestbut after doing that it's probably revved to a good 10-15k rpm!
Damn! not good Ian....
fingers and toes crossed that its something easily sorted
Checked all the timing and then noticed that the fuel rail was loose. On closer inspection the rail retaining lugs had snapped clean off so it seems the extra boost from the over reving has tried to blow the injectors out and only the throttle cable bkt has kept them from completely blowing out of the manifold!!!:
Decided to swap the injectors for the saab reds ive got as maybe it had done the injectors in at the same time as the rail :
ok i can deal with that, turbo elbow off and another bolt snapped
. Was proper spewing at this point so packed up and had a fair few beers!!.
